• 03.01.2026, 09:52
stevebit56
Aquacomputer Water Block for Aquaero 5, G1/4
Sonntag, 2. Februar 2014, 19:21
Hi everyone I would like to know if anyone is using the (Aquacomputer Water Block for Aquaero 5, G1/4) on the Aquacomputer Aquaero 6 XT USB Fan Controller? Or does any of the admins know if it will fit or is there one made for the Aquaero 6 XT that I haven't see yet??? any help please :huh:
:P [color
Namron
Sonntag, 2. Februar 2014, 21:09
You need the new AQ 6 Heatsink HERE which has mounting points then for the AQ5 waterblock...... Your going to need a lot (& I mean alot) of fan's/pumps connected to the AQ6 to warrant putting on a waterblock, I suspect most won't even require the New Heatsink IMO :)
stevebit56
heatsink
Mittwoch, 5. Februar 2014, 15:23
Thanks Namron for the info I will try the heatsink first I want to keep my Aquaero 6 nice and cool. I'm investing $225 on it and heat kills electronics so I want this controller to last a long time! :)
:P [color
bcikota
Donnerstag, 6. Februar 2014, 21:05
That heat sink is so sexy they should just include it as standard delivery.
Kind regards,
Boris.
