• 12.02.2026, 01:23
Psychor
Analyze Data / Data Log Bug - AS2014 v2.3
Samstag, 26. Juli 2014, 22:28
I had hope that the issues with graphing had been sorted out in the latest release but it looks like some still persist. In the current release it appears that once you add a 3rd data set to graph the Y axis is doubled (i.e., displayed twice). I tested this using both virtual sensors and native AQ5 temperature sensors. Same issue.
»Psychor« hat folgende Bilder angehängt:
Psychor
Samstag, 26. Juli 2014, 22:33
This is what happened when I graphed 4 AQ5 sensors and 1 MPS sensor together. Notice the Y axis.
»Psychor« hat folgendes Bild angehängt:
Psychor
Samstag, 26. Juli 2014, 22:53
This is what both graphs look like when displayed on an "Overview page." Notice that even though the 3rd GPU is graphed under "Analyze data" it's completely missing when the graph is displayed on an "Overview page."
Montag, 28. Juli 2014, 13:10
This problem is known and will be fixed with the next update.
Psychor
Sonntag, 14. September 2014, 18:23
Any idea when we might see the next update? Thanks.
