• 01.04.2026, 03:47
duniek
aquaduct xt 360 TORX SIZE?
Donnerstag, 31. Juli 2014, 02:55
hello
my aquaduct is dead and not working at all
I will start to disasssemble whole unit.
What TORX tool size for opening top part of unit?
Dieser Beitrag wurde bereits 3 mal editiert, zuletzt von »duniek« (31. Juli 2014, 04:21)
Donnerstag, 31. Juli 2014, 08:42
It is T20.
duniek
Donnerstag, 31. Juli 2014, 22:14
It is T20.
OK THANKS
Also can you send me pinout of 9 pin socket ?
I figured it out by myself but my pump isnt working :(
I tried run it DRY (of course i shouldnt but i want only check it for seconds, but pump not response)
aquasuite tells me PUMP status is OK (even when i plug out pump from "motor" connector)
EDIT//
I found 220V @ ~10V AC 1200mA PSU from creative speakers and pump working
I plug pump with only aquastream @molex - not working ;(
What Am I doing wrong?
Dieser Beitrag wurde bereits 3 mal editiert, zuletzt von »duniek« (6. August 2014, 21:52)
