• 27.02.2026, 07:25
Aquaero 5 & 6 interchangeability
Dienstag, 5. August 2014, 17:49
There are multiple instances of products (example) listing compatibility with Aquaero 5 without mentioning Aquero 6. Are these products actually not compatible with the Aquaero 6, or is it a product description update issue?
Donnerstag, 7. August 2014, 00:02
After searching for a while, I think I found the answer - Aquaero 6 uses Aquaero 5 accessories
Dieser Beitrag wurde bereits 3 mal editiert, zuletzt von »InfoSeeker« (7. August 2014, 00:12)
