• 05.04.2026, 06:33
ZGIERA
AQUAERO 6XT, Poweradjust 3 Ultra issue - doesn't see any additional fans connected to poweradjust
Dienstag, 4. November 2014, 22:12
I can see additional fan channel connected to my poweradjust 3 ultra when I have only one connected poweradjust 3 to my aquaero which
I can see on aquasuite 2014-2.3 version also, but every connected fan channel to poweradjust 3 ultra is gone
when I connect another poweradjust 3 ultra to another poweradjust 3 Ultra in daisy chain.
I can see this kind of message on aquasuit "poweradjust as fan 5, bus address 50" when one poweradjust 3 ultra is connected only.
so tell me please where is a problem?
Is that kind of hardware conflict issue or one of my 2 poweradjusts is broken?
I'm pretty fresh with this kind of stuff and I'm still learning myself.
Thanks for advice
bcikota
Dienstag, 4. November 2014, 23:45
Hello ZGIERA,
You need to connect each PA to the USB individually and change their buss address from the Aquasuite, because, by default, they all have the same address.
So leave the first one at 50 for instance, give the second one address 51 and so on...
Kind regards,
Boris.
ZGIERA
Mittwoch, 5. November 2014, 07:04
thank you for advice me.
I did as you say last night, and it works :)
Cheers
