• 03.05.2026, 17:52
Wredny
Will AC Farbwerk work with Aquaero 5 LT?
Freitag, 30. Januar 2015, 18:48
Will AquaComputer Farbwerk (aquabus edition) work with Aquaero 5 LT?
bcikota
Freitag, 30. Januar 2015, 21:47
Hi Wredny,
Yes, farbwerk should work with AQ5 LT. Keep in mind you have two versions of the unit, one with aquabus and USB and another one with USB and a Bluetooth module.
Both versions can work as standalone units and can be configured through USB.
Kind regards,
Boris.
Samstag, 31. Januar 2015, 00:21
Between the two versions (bluetooth & aquabus) only the aquabus version will work with the aquaero 5 LT. The two protocols uae the same port and are mutually exclusive.
So Shoggy says. :)
