• 22.02.2026, 02:50
divve
aquaero fans per channel
Dienstag, 6. November 2007, 10:26
Is it safe to connect 3 x Papst 4412 F/2GL fans on a single channel of the Aquaero 4.x? The fans are specified as being 1.25W, which is well with-in the 10W per channel margin. However, I read that the load or heat development on the controller will be greater when running the fans on less than full speed.
Thanks.
Re: aquaero fans per channel
Dienstag, 6. November 2007, 17:06
That's no problem :)
