• 26.03.2026, 18:42
Question for support re Unicode characters usage in aquasuite 2015-4
Samstag, 28. März 2015, 20:57
I have a couple virtual temperatures that show the delta between water in vs water out. and water in vs. air ambient.
To reduce the title length in the gauge, I use the Greek capital letter Delta 'Δ' (U+0394):
On initial blush all seems good:
But once I exit and restart aquasuite, the 'Δ' is replaced with a '?':
Is there an issue using Unicode?
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »InfoSeeker« (28. März 2015, 20:59)
Montag, 30. März 2015, 07:10
only the normal charset vom 32(dec) up to 255 (dec) is supported. The most of the charcters of the ISO 8859-1 (Latin-1) charset are supported.
http://cs.stanford.edu/people/miles/iso8859.html
Special Characters
