• 11.04.2026, 18:44
PiotrMKG
Aquasuite 2015-5
Donnerstag, 16. April 2015, 08:57
I just installed new aquasuite and I have strange readouts in this program. My flowsensor (prod. no 53068 ) is showing 0,1gpm in program and the same sensor is showing 1,5gpm in Aquaero 6XT, and my pressure sensor MPS was showing much less pressure than now. Before update everything was fine, Aquasuite and Aquaero was showing the same values. What is going on?
Railgun
Donnerstag, 16. April 2015, 10:05
I see no change log, in German or otherwise.
PiotrMKG
Donnerstag, 16. April 2015, 10:23
aquasuite 2015 Version 5
I solved my problem, a clean install + reset to default settings mps pressure sensor and everything is back to normal.
