• 13.05.2026, 05:39
josetortola
Support to HWInfo remote sensor monitoring.
Mittwoch, 22. Juli 2015, 12:55
HWInfo has just launched its version 5.02 some days ago. It includes many new features , and one that I was expecting for since some time ago: remote sensor monitoring.
That enables HWInfo to "act as a server" of all it measured data, and other PC in the same network with also HWInfo to be connected to "the server" ones and read and display all its data.
The idea begin with thinking about having displayed information of some Aquaeros in the same network in just one overview page in one of the PCs of the network. As HWInfo could act as source for Aquasuite software sensors and also read Aquaero's data, having HWInfo passing its data through the network could be the thing needed to achieve this . Martin was extremely kind and fast with the main idea, and implemented it in previous HWInfo beta versions . But when testing those betas, it was discovered that the 3rd party applications/plugins (including Aquasuite) will need to be updated to properly handle remote sensors.
Here is also the main topic on HWInfo forums with the information about it.
So now it is possible to see in one PC the readings of all the Aquaeros installed in the network PCs with HWInfo, and that's really great, I can be aware of the status of liquid cooling systems installed in the network from just one PC. And I have to thanks once again Martin (HWInfo creator) for making that possible.
But now that we're so close to the next level, having all those information shown in jus one Aquasuite overview page, I was wondering if Aquasuite will implement that option :rolleyes:
Thanks in advance.
josetortola
Mittwoch, 19. August 2015, 16:26
I know that summer is not the best time to ask for updates... but, are there any news on this?
Thanks in advance.
Donnerstag, 20. August 2015, 08:47
We are on it but I can not tell if it will be inside the next update.
josetortola
Donnerstag, 20. August 2015, 13:32
Great news then.
If it is not inside the next update, I hope it reaches some other update in the future.
Thanks!
