• 28.01.2026, 13:07
Salt
Waterblock for MSI 970 4GD5 OC
Dienstag, 25. August 2015, 16:44
I'm looking full waterblock for
MSI GTX 970 4GD5 OC
It is 980 reference board.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Salt« (25. August 2015, 16:49)
Mittwoch, 26. August 2015, 08:58
You should be able to use every GTX 980 block from us but take care: the card is missing the NVIDIA imprint above the PCIe contacts so it could be possible that it uses the same layout but a different placement of parts. For example resistors could use a different height.
