• 24.01.2026, 20:34
Railgun
Power adjust/farbwerk red
Mittwoch, 16. September 2015, 15:55
In light of the move to blue LEDs, how about an option, or providing a P/N for the LEDs for the farbwerk and power adjust LEDs in a red variant.
I didn't know you'd made the move to blue at the time I picked up the above...which doesn't jive with my build's look I was going for. Easy enough to do it, but since you're making both for the Aquaero...
Freitag, 18. September 2015, 20:27
There will be no red variant available in the future. You can change the LED yourself if you want. It is a 2mm LED.
The change to blue for all devices has been planned some time ago. The fact that both variants are currently available for the aquaero is just a transition period. We will see how things are going there but for the long term we have only blue in mind.
Whatever color we would select, it will be always the wrong for someone ;)
Railgun
Montag, 21. September 2015, 23:49
RGB LED is the only option then. :D
