• 09.01.2026, 10:00
Hoe
AquaSuite Dashes always on top?
Donnerstag, 15. Oktober 2015, 12:25
Hello,
I would like to force some of or if not all of my AquaSuite meters above all other applications, specifically teamspeak, I am running it on a Windows 10 Tablet showing stats from my main water cooled PC on that but I can't see to find a way to force the meters on top, is it possible?
Thanks
Stuart.
Hoe
Donnerstag, 15. Oktober 2015, 16:12
Here's a picture to give you a better ides, as you can see the Meter's look very faded through TeamSpeak, I could increase transparency but obviously with a cost to TS usability, the clock with is done using RainMeter is always on top and therefore not faded...
Dienstag, 20. Oktober 2015, 11:29
That will not be available in the future. The current desktop mode was already a hard piece of work since Windows does not really like stuff that is present all the time.
