• 18.05.2026, 09:56
yevonxxx
aquaero 5 lt + skylake i5-6600k and windows 10
Dienstag, 1. Dezember 2015, 18:58
hi,
i'm an happy owner of an acquaero 5lt,always used with my so old core 2 duo e8400 under windows 7,
so i decided to upgrade my cpu to a skylake i5-6600k under windows 10,still have to put together my pc but wanted anyway to know IF:
1)does acquaero support new skylake cpu and windows 10?
2)which software does it use to get cpu/gpu/etc(virtual software sensors) data like it was "open hardware monitor"?
i ask cause it seems that "open hardware monitor" still not support skylake cpu.
ty in advance and keep up the good work.
Mittwoch, 2. Dezember 2015, 08:50
The aquasuite software also runs under Windows 10 of course. The CPU and other hardware has no effect since the aquaero works autonomous.
At the moment the following monitoring tools are supported:
- HWiNFO
- AIDA 64 Extreme Edition
- Open Hardware Monitor
yevonxxx
Freitag, 4. Dezember 2015, 06:21
ty very much. :)
