• 22.01.2026, 18:16
Dundys
PA3 3pin Header
Montag, 29. Februar 2016, 15:31
I have a lot of those LED strips:
https://www.dazmode.com/store/product/12…ed-strip-white/ : they are dimmable 2pin LEDs
I have some of them connected to 12V and some to 6V PCB splitter board but I would like to adjust their voltage to either dim them or make them brighter. If I connect them to Aquaeros 4-pin header I am able to do it, but when connected to PA3 3pin fan header I cannot adjust it, it can only be on or off.
Can anyone help please.
Thanks
Dieser Beitrag wurde bereits 9 mal editiert, zuletzt von »Dundys« (29. Februar 2016, 19:52)
Dundys
Montag, 29. Februar 2016, 20:14
Solved :)
