• 06.01.2026, 12:21
SoMBrA
Aquaero 5 XT increasing / decreasing fan speed every 30-40 seconds
Samstag, 26. März 2016, 03:48
Hello.
So this is happening on 2 channels at the moment.
When I play games, the fans will go up to 100% power and then down to the controller setting adjustment I have at the Aquasuite.
This happens every 30-40 seconds all the time (cant read the timestamp properly). When I stop playing the game then it just keeps at the preadjusted speed from the Aquasuite.
Any ideas? I havent linked any sensor to the controller so it increases speed fans or anything like that
Samstag, 26. März 2016, 14:27
Sounds a lot like the overheat protection is kicking in. You should check the temperature of the channels in the fan tab. Since channel 1+2 and 3+4 share a sensor, they will always react to a too high temperature as a pair.
