• 22.02.2026, 00:33
dawg
add LT to control more fans
Samstag, 3. September 2016, 19:08
will the 6xt work if add 5LT to control & monitor extra fans ?
Sonntag, 4. September 2016, 00:12
you can use an aquaero 5 LT as a slave device, so you will have 4 more fans (voltage controlled) and 4 more temperature sensors
or you can use both aquaeros as independend devices and controll each of them by an own tab in the aquasuite
dawg
Sonntag, 4. September 2016, 03:01
wonderful
will the fan rpm of each fan on the slave be available in aqua software ?
