• 22.02.2026, 00:32
meezits
Res with d5 base leaking! please help
Samstag, 22. Oktober 2016, 23:42
Hello everyone,
I just went to leak test my computer and all the liquid, not too much only because I just started filling started leaking out the back on the res. There;s a little slot where the liquid comes right out. I looked at all the product pages and there definitely isn't a seal or gasket that goes out the back of there. :S
Can someone help me please.
http://shop.aquacomputer.de/product_info…roducts_id=2924
You'll notice a little slit on the bottom, that's where its coming out at.
And here is my base
https://shop.aquacomputer.de/product_inf…roducts_id=2926
Thanks for your time
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »meezits« (23. Oktober 2016, 00:36)
meezits
Sonntag, 23. Oktober 2016, 01:26
For anyone looking at this, dont worry. I'm an idiot.
I didnt put the g1/4 stop on the "out" side and it was leaking back up and out the back.
All fixed now
GTXJackBauer
Sonntag, 23. Oktober 2016, 08:34
Yikes. Always double check your work when moving onto the next phase. Very lucky and glad you got it all worked out.
