• 18.05.2026, 20:02
skingun
Flow sensor high flow G1/4 for aquaero, aquastream XT ultra and poweradjust
Samstag, 17. Dezember 2016, 15:44
Hi All
I bought a flow sensor but cannot get a reading to display in aquasuite or on the aquaero (I have a 6 XT). The flow meter cable I purchased is 18cm long so i used a 3 pin extension read to reach the aquaero - this should work right? I connected this to the 3 pin flow header on my aquaero. Can anyone help?
Montag, 19. Dezember 2016, 15:39
Any chance to test it without the extension cable? Normally it should work but who knows...
skingun
Montag, 19. Dezember 2016, 20:04
Ordered a 70cm cable today from AC direct. Let's see if that will fix it.
skingun
Donnerstag, 22. Dezember 2016, 13:30
70cm flow cable works! Must have been a faulty 3 pin extension.
PLEASE CLOSE THREAD.
:thumbsup:
