• 22.02.2026, 00:23
detc0rd
Question about the Bluetooth Farbwerk controller (Solved)
Mittwoch, 8. Februar 2017, 17:38
Helo everyone, i just finished my custom build , and connected the bluetooth farbwerk controller.
I have installed the app to control, but my led just keeps cycling through colors, but i want it to be static color, doesent seem like im able to control anything from the bluetooth app, i only get up saturation and brightness, but it doesent happen anything when i try to change, is there something im missing ?
Thanks for any help in advance.
Best regards
Chris
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »detc0rd« (8. Februar 2017, 18:56)
detc0rd
Mittwoch, 8. Februar 2017, 18:56
Nevermind i figured it out :) I had to connect it to the usb on the motherboard, and install software on my computer to make it controllable from 3rd party like bluetooth :)
