• 02.04.2026, 03:58
tbuttery
Aquasite 2017-1.3 Not Installing
Mittwoch, 1. März 2017, 01:13
All,
I just upgraded to a M.2 Drive, so I did a system wipe and clean install of Windows 10, but now when I try to install the Aquasuite Software I get this error...."Download Failed...Please Try Again Later". Any one have any idea what is going on? Nothing has changed since my last intall, except for the new M.2 Drive.
Any help ASAP would be appreciated!
Thanks
Fieldrider
Mittwoch, 1. März 2017, 01:18
Is your clock and date set correctly? I've read that the Downloadserver could have problems with that if it's not.
GTXJackBauer
Mittwoch, 1. März 2017, 01:45
This.
As long as your Win 10 is installed on your primary M.2 drive, you're good to go on that front. Networks in general like being sync'd with the right time, etc.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »GTXJackBauer« (1. März 2017, 01:46)
tbuttery
Mittwoch, 1. März 2017, 15:26
I must be a big dummy....Restarted my PC....date and time correct, and then it downloaded when I tried again.
This.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »tbuttery« (1. März 2017, 15:29)
