• 13.05.2026, 21:45
Piospi
Thermalpad vs pastę for aquaero heatsink.
Freitag, 9. Februar 2018, 10:39
Standard pads have been mistakenly damaged. I need to re-mount the heat sink on my aquaero. Do I have to buy new thermalpads or I can use thermalpaste from Grizzly?
If I must buy thermalpad, what thickness and companies can it be? I think about Gelid GP-Extreme Thermalpad 120x20x0.5mm TP-GP02-A. Its good?
Freitag, 9. Februar 2018, 20:36
You have to use Thermal pads - otherwise you can damage some parts on the PCB.
Piospi
Freitag, 9. Februar 2018, 22:00
Okay I understand :) What is the thickness of the original thermalpads from Aquacomputer?
