• 02.01.2026, 09:51
zerophase
Does AQ 5 / 6 screen replacement fit XT?
Freitag, 23. März 2018, 04:59
I damaged the screen awhile back taking a gouge out of the screen. Would this fit the XT? https://shop.aquacomputer.de/product_inf…roducts_id=3154
Freitag, 23. März 2018, 13:53
No, this is an optional display cover for the aquaero 5/6 PRO.
What is damaged? Just the cover or the display itself? Both are not available in the webshop but you can get them as spare part by sending an e-mail.
zerophase
Freitag, 23. März 2018, 18:10
Just the cover is damaged. The front of my Enthoo Primo popped off while draining the loop, damaging the cover in the process.
Freitag, 23. März 2018, 20:58
OK. As said, can be ordered by mail.
