• 15.11.2025, 06:26
ZenMaster
Aqualis eco 880 broken
Donnerstag, 5. Juli 2018, 10:07
Greetings,
After leak testing the aqualis I disassembled it to remove the fountain effect and add the steel part but I heard a "chink" as soon as the top came off. :( No force was used and I am very weak. Is this normal?
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »ZenMaster« (5. Juli 2018, 10:09)
Donnerstag, 5. Juli 2018, 12:25
I recommend to send an e-mail with the photo and your invoice number or address details if it was purchased from somewhere else.
