• 04.04.2026, 10:13
Mazdabater
High flow usb sensor not reading flow rate
Donnerstag, 26. Juli 2018, 12:15
Hey guys, I finally got around to installing my flow meter last night. I have upgraded it to the latest firmware and it's reading the water temp internally but the flow rate is stuck on 0. Is there something I could be missing here? The only thing connected to it is the USB connection from the mobo.
»Mazdabater« hat folgende Datei angehängt:
  • Capture.JPG (167,19 kB - 172 mal heruntergeladen - zuletzt: 25. März 2026, 08:35)
Donnerstag, 26. Juli 2018, 17:18
It looks like you have one of the MPS flow sensors and you may be outside the range it is designed for.
If you could provide the part number, a screenshot of the flow sensor System Tab, and a concise description of the cooling loop (# pumps, # water blocks)
Mazdabater
Freitag, 27. Juli 2018, 08:10
It's definetly the high flow usb and not an MPS one. Current loop has
2 x 480mm rads
1 x 420mm rad
2 x EK D5 pumps
1 x cpu block
1 x motherboard block (on Maximus X Formula)
1 x gpu block
It will have another cpu block and possibly a gpu block in the loop when I get my mini ITX system back from RMA
  • Capture.JPG (129,29 kB - 142 mal heruntergeladen - zuletzt: 25. März 2026, 08:35)
AE5probigNGslave
Freitag, 27. Juli 2018, 21:00
From your another feed is clear that you had problems with power supplies that blow up your MB. I think that you have broken MPS too.
Or you can try disconnect MPS from loop and try to blow by mouth to propeller blade and than you can be sure that rotating. Only advice.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »AE5probigNGslave« (27. Juli 2018, 21:08)
Mazdabater
Freitag, 27. Juli 2018, 23:09
The glow sensor was only just added so it was never hooked up to the other psu. I did blow through it and didn’t hear anything moving so I guess my curse continues and I have another dodgy part.
Mazdabater
Dienstag, 14. August 2018, 12:30
So it seems that I've been given a faulty one then? Has anyone delt with aquacomputer for warranty? Seems like it would just be easier to take the hit and buy a new one
Dienstag, 14. August 2018, 14:09
I have always found aquacomputer to be fair and prompt.
Contact support at support@aqua-computer.de and let us know what your experience is.
