• 04.01.2026, 14:44
Blade Runner
Farbwerk in Car
Donnerstag, 2. August 2018, 20:24
I am trying to use a Bluetooth Farbwerk to run some AQ RGB strips in a car.
My question is, I have 12v but no 5v in the car, can I connect 12v to the 5v input without damage/ overheating etc??
I have tried just the 12v supply and nothing lights up, if I daisychain the 12v to the 5v the Farbwerk works but I am worried about doing that ?
Donnerstag, 2. August 2018, 20:48
You need the 5V. Without the 5V the farbwerk is not running
Blade Runner
Donnerstag, 2. August 2018, 22:28
Thanks Sebastian, I will get a 12v to 5v step down transformer then.
Freitag, 3. August 2018, 06:50
Ist not an good idea to use electronic devices in a car.
In a car you can have voltages from 8.. 16 on the 12V line and voltage surges up to 70V.
It is not recommended to install any electronic devices in a car that are not intended for this purpose.
