• 12.11.2025, 08:43
Silky_
D5 Pump to 4 pin???
Freitag, 7. September 2018, 23:29
I have a PWM D5 pump and would like to know if I can remove the molex and connect power thru the PWM header since I'll be powering it thru AQ6? ?(
Montag, 10. September 2018, 11:43
It's possible but does not male much sense. You should take the power from the PSU an only connect the PWM and RPM signal to the aquaero.
