• 12.04.2026, 03:20
Inside aquaduct 360 XT
Dienstag, 27. November 2007, 21:41
The aquaduct 360 XT mark II should not be opened by the customer. Since we would like to show from what it is built, we have taken a photograph of the more than 180 components.
One should better not disassemble his own aquaduct. More than 30 o-rings must work properly so that an aquaduct 360 comes through the final highly sensitive leak tightness test.
Moreover, we show you a photo of the internal construction of the aquaduct mk II series here.
Top_Nurse
Re: Inside aquaduct 360 XT
Mittwoch, 28. November 2007, 10:28
Much better design! Thanks for ditching the 6 feet of tubing.
Congratulations! ;D
Now how about in the water temp sensing? ;)
heed
Donnerstag, 29. November 2007, 08:13
Shoggy, I can't see pics. Can you give me a direct link to them? Thanks.
Donnerstag, 29. November 2007, 10:34
http://www.aqua-computer.de/images/produ…60_XT_3_800.jpg
http://www.aqua-computer.de/images/products/aquaduct/ad_360_XT_2_800.jpg
heed
Freitag, 30. November 2007, 08:28
JorisS
Samstag, 15. Dezember 2007, 12:10
How does one know if one has a mark II?
pharao
Samstag, 15. Dezember 2007, 12:31
compare the pictures :)
mark I
http://forum.aqua-computer.de/index.php?…ad&threadID=176
mark II
http://forum.aqua-computer.de/index.php?page=Thread&threadID=199
JorisS
Samstag, 15. Dezember 2007, 13:02
Ok so I just recently coughed up 400 euros for this unit, NOW you come with a much improved remake? :'(
x-stars
Montag, 17. Dezember 2007, 10:03
Bad Luck. But the "old" aquaduct isn't bad, just because there is a new "better" version. And look at the aquaero-rotation-button: In my opinion it looks cheap and crappy, so be happy you got a nice aquaduct :D.
Montag, 17. Dezember 2007, 11:14
Some of the changes has already been implemented during the production of the Mark I. So your aquaduct is maybe very simulair to this one - except the electronics.
JorisS
Dienstag, 18. Dezember 2007, 01:36
Kyle XY
RE : Inside aquaduct 360 XT
Samstag, 6. Februar 2010, 09:50
By the way, is it possible to draw some arrows in order to indicate the water flow through the radiator, the pump and the Aquaduct itself ? It's always a question for me and for people who discover my Aquaduct 360... Thanks !
Kyle XY
Mittwoch, 10. Februar 2010, 19:18
Shoggy ?
Kyle XY
Mittwoch, 17. Februar 2010, 06:51
Youhou !!
Nobody ? :sleeping:
Kyle XY
Sonntag, 21. Februar 2010, 08:20
Nobody cares ;( or (worse) nobody knows, even the administrators ??
I would like to know the direction of waterflow because it's not clear, through the black base, the radiator, the upper aquaduct and the pump. For example, I am wandering if the pump uses the water once refreshed ? Does the water go through the radiator before the aquaduct ? And so on... Whatever, a simple picture with arrows for wtare flow is better than a large discussion, isn't it ?
Please, answer me !!
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Kyle XY« (21. Februar 2010, 08:23)
koaschten
Sonntag, 21. Februar 2010, 15:31
From a performance view it doesn't really matter. From a functional view I'd trust them to get basic stuff like "reservoir before pump" right ;)
Zitat von »Dino«
...lauter spinner ;)
dino
Kyle XY
Montag, 22. Februar 2010, 21:26
Honestly, I don't think it doesn't matter. I like to know what are the technics in the devices I bought. For example, I imagine you don't buy a sports car without knowing what there is below the hood, or closer, about your last graphics card. 8)
I spend a lot of money for my Aquaduct, I hope at least to know how it runs ! Don't you agree ?
I have another topic about Aquasuite and two adjustments but wihout answers since a couple of weeks. Maybe you can help ? ;)
Thanks !
Kyle XY
Sonntag, 28. Februar 2010, 09:11
Mmmmhh... Maybe would it be an industrial secret ? :rolleyes:
slame
Sonntag, 7. März 2010, 13:45
I mean ... there are arrows on the two connectors .. just follow them .. then you know the waterflow.
or am i misunderstanding your question ?
Kyle XY
Montag, 8. März 2010, 19:17
Thanks you for your answer and I'm sorry if I were not accurate enough.
I understand how is the flow for the connectors themselves. I meant I would like to know the flow direction throughout all parts (radiator, pump, aquaduct,...) with arrows on the picture given by Shoggy. Do you know how the flow is designed ?
