• 06.11.2026, 08:21
alexwill22
Freitag, 14. Dezember 2018, 21:20
Can 3 of these pumps be detected in the aquaero or aquasuite software?
Dienstag, 18. Dezember 2018, 05:37
I thought I had seen the question asked, but I cannot find it, so I ask again: is it possible to make a virtual temperature with the D5 NEXT & aquasuite?
pbsqt
Samstag, 15. Juni 2019, 08:14
Hello! For your advice please: I have a Gigant 3360 and will start a new build very soon with CPU (9990XE so lots of heat) and 2 x GPU waterblocks.
On another build I’ve had an Aquastream for many years running fine and I love the pump and the silence. For the build with the Gigant would you recommend I get 2 x Aquastream (in series) or 2 x D5 Next? (Or just 1 of either pump?). The pump(s) will be in the PC case. But I hope to make it very silent. Thank you very much.
