• 29.03.2026, 14:00
DirtyBear
Aquasuite 2018-6
Sonntag, 7. Oktober 2018, 02:43
After I reinstall Win 10 and when I try to install Aquasuite it was fail !!!
It said " Download failed Please try again later, Make sure your System time is set correctly "
whats that suppose to means ?? make sure my system time is set correctly ???
I have no idea whats going on !! ???? please help
»DirtyBear« hat folgendes Bild angehängt:
GTXJackBauer
Sonntag, 7. Oktober 2018, 10:27
Make sure your time and date on your PC is correct with real time. If it's not, it will have issues with the servers in general unless a complete different issue is at hand.
DirtyBear
Sonntag, 7. Oktober 2018, 11:29
I already check every single Time and date in my System and still no luck
( maybe got to be in German time and date :S )
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »DirtyBear« (7. Oktober 2018, 11:31)
Sonntag, 7. Oktober 2018, 13:21
DirtyBear
Sonntag, 7. Oktober 2018, 16:09
Yes something like that but you can not set the Time zone by auto , you have to un click auto and set it by yourself 8|
sounds a little bit stupid :wacko:
