• 11.04.2026, 16:09
levifig
Quadro + Splitty4 + EK Vardar RGB
Freitag, 9. November 2018, 16:34
Hey guys,
I have 12x EK Vardar RGB fans in my system. They don’t have addressable RGBs, so I know I’m limited to a single color per fan. What I’m wondering is if I’ll have access to the individual fans if using a Quadro + Splitty4… I know that if a use an RGB splitter, I can only “assign” a color per splitter, but I was hoping the Splitty4 would allow me to customize each individual fan. Basically the Splitty4 giving me 4 individual channels, that I could configure. That’s how I assumed the product worked. What got me all confused was the compatibility section on the product page: Corsair and NZXT only. Is that regarding fans with addressable RGBs or any fan at all?
Thanks! ^^
—LF
Hufeisen
Freitag, 9. November 2018, 19:12
Quadro and Splitty4 only work with addressable RGB.
For your EK Vardar RGB Fans, you need a Farbwerk and a custom adapter cable because the Fan and the Farbwerk have different pin layouts.
https://shop.aquacomputer.de/product_inf…roducts_id=3232
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »Hufeisen« (9. November 2018, 19:29)
levifig
Dienstag, 13. November 2018, 07:47
Thanks for the info!
So that raises another question: how many EK fans would I be able to control (individually) with a Farbwerk? 4 per farbwerk?!
Thank you again! :thumbsup:
