• 03.11.2025, 03:48
szczur333
aquero not recognized by usb (aquasuite)
Sonntag, 9. Dezember 2018, 16:36
hello
i have:
aquero 4.0 (4.12)
aquaero 5 LT
aquaero 6 PRO
aquaero 5 XT
all controllers was in perfect working conditons (i didnt use them for 1-2 years) and now I try to plug them
only 5LT is recognized by system
others
i plug USB and USB + power - no difference
any ideas?
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »szczur333« (9. Dezember 2018, 16:39)
selvakumar1989
Sonntag, 9. Dezember 2018, 16:41
do a firmware update to all devices
szczur333
Sonntag, 9. Dezember 2018, 16:47
I updated 5 LT bcoz its recognized
rest ITS NOT recognized so i can't do it
EDIT//
ok - i know why
i have to close app and run installation exe with aq6pro plugged in then i can choose 2016 version
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »szczur333« (9. Dezember 2018, 17:21)
Sonntag, 9. Dezember 2018, 17:22
aquero 4.0 will not work with aquasuite 2018
it could work with a very old version of aquasuite, but most mainboards are not compatible anymore
szczur333
Sonntag, 9. Dezember 2018, 17:42
yes, i heard about that - 4.0 isnt recognized even but install exe app
but its still be good as standalone controller i think - is it possible to update firmware/change language somehow ?
selvakumar1989
Montag, 10. Dezember 2018, 05:13
then contact
https://forum.aquacomputer.de/index.php?…er&userID=10863
he will help you with old version of aquasuite
selvakumar1989
Montag, 10. Dezember 2018, 05:15
aqua computer please add support for old devices https://forum.aquacomputer.de/index.php?…er&userID=10863
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »selvakumar1989« (10. Dezember 2018, 05:16)
M40
Sonntag, 16. Dezember 2018, 20:52
I would also love if there was a way to get hold of some software to be able to use the good old Aquaero USB 4.0 controllers.
Got 2 of them in mint condition, and am now looking into the possibility to get them to work with new HW. Z370 Mobo and Win10.
Should i also mail the same person about this?
