• 22.02.2026, 03:56
Silky_
VISION Touch Table Top Unit connection to Aquaero 6 LT
Freitag, 25. Januar 2019, 20:31
How does the Vision Unit connect to the Aquaero 6 LT?
Does the USB take care of that or does it need another cable to do so?
Thank you
Hufeisen
Freitag, 25. Januar 2019, 23:02
you cant connect the vision unit to the aquaero.
you must connect the vision unit with usb to your mainboard.
then you can use the aquasuite software to access the vision unit.
