• 14.02.2026, 23:13
aquasuite panel
Freitag, 1. Februar 2019, 18:16
I wanted to share a little trick I used on my aquasuite monitoring panel that may be useful to others.
Initially I had a separate gauge for air, fluid, & air/fluid Δt (3 gauges), but that took too much space. So I decided to combine them into one gauge.
I find it useful that having the air & fluid temps on one gauge automatically displays the analog Δt between the two. I added the digital Δt for accuracy.
Railgun
Freitag, 1. Februar 2019, 19:07
Looks pretty slick.
I’ve been playing with Grafana a lot lately for some work related...work...
While I’m sure that you can tweak the AS panel to a degree, I’d love to know whether the data can be exposed and pulled into an external tool as above to also rope in other metrics for a true single pane of glass.
