• 29.01.2026, 05:39
Edropian
How Can I Put Custom Images On The D5 Next Display?
Montag, 25. Februar 2019, 21:39
As the title says ... my question is plain and simple :D
I am just wondering not "IF" but "How" I am able to load custom => images <=
on the D5 Next display.
PS: I am not referring necessarily on values from sensors
but on static images too like the ones that appear when it informs us about the
Firmware :thumbsup: and on powering on when it states the "Aquacomputer" brand.
Thanks in advance :D
Dienstag, 26. Februar 2019, 09:28
No this is not possible.
Edropian
Mittwoch, 27. Februar 2019, 13:34
It could have been a really cool feature though for future firmware updates, don't you think?
Specified image type - dimensions and storage size (put them in the appropriate folder) and you are ready to go
given the fact that you will, that way, be given the option to choose that screen from the setup menu ;)
Even with prefixed forms for adding specific sensors you can add additional options for system info through the
screen.
I am looking forward to such functionality because it is so simple to implement on your end and practical on ours ;)
:thumbup:
