• 15.04.2026, 20:37
asphalt
Aquaero 6XT disply stopped working
Montag, 11. März 2019, 01:44
Good Afternoon,
I apologize if this has been answered in another thread but, I am not sure if I need to RMA the unit back to you guys. After turning on my computer today, I notice that the aquaero 6XT was displaying thick and thin white lines and blocks instead of the normal data from my system. I shut down my computer and I tried unplugging the aquaero directly from the molex connector and re-plugging it in and starting the computer back up with no luck. Now when I try and power up the aquaero, there is no display at all including the red directional and set buttons on the face of the unit. Is there something that I can try and do to fix the unit? Thank you in advance.
Montag, 11. März 2019, 05:29
asphalt
Montag, 11. März 2019, 16:24
Thank you, sent them an e-mail.
