• 01.01.2026, 14:04
C9Flame47
Aquasuite issue for D5 NEXT
Dienstag, 2. April 2019, 06:11
I was trying the aquasuite software and it automatically closes when I click the settings tab of RGBpx lighting.
I have .net 4.7.2 installed
When I look in the event viewer I see an error in the application. I am attaching the logs.
»C9Flame47« hat folgende Datei angehängt:
  • error.txt (23,29 kB - 110 mal heruntergeladen - zuletzt: 18. Dezember 2025, 18:05)
Dienstag, 2. April 2019, 07:42
Reset your pump to factory defaults (system tab).
Is your aquasuite up to date? (2018-10)
C9Flame47
Dienstag, 2. April 2019, 07:59
I tried resetting it to factory defaults. I also tried uninstalling and reinstalling the software.
Yes its the latest version.
Dienstag, 2. April 2019, 08:09
Can you test the Pump and the software with an other computer?
You can use only the controller unit for testing.
