• 12.04.2026, 15:27
Fenol
Upgrading firmware from PRO to XT
Sonntag, 23. Juni 2019, 15:11
Hello!
I have had Aquaero 6 PRO for some time and now in the process of rebuilding my PC with custom computer case. In the previous computer case Aquaero 6 was held in 5.25" bay but current case doesn't have any. And it's ok - I'll just cut out the window for it, no problem.
But I thought that, if I'm creating new face plate for Aquaero 6 anyway - why not add additional 4 function buttons like in XT version? As far as I understand, Aquaero 6 LCD module has 8-pin header that is used to connect 7 capacitive buttons in XT version (some of the pins are shared with 3 hardware buttons already).
Pinout is not a problem. Problem is - how to flash XT firmware so that additional 4 buttons become usable?
Sonntag, 23. Juni 2019, 16:42
The short answer is: this is not possible.
Fenol
Montag, 24. Juni 2019, 02:48
Is there such thing as “different” XT/LT/PRO firmware or firmware is the same and it is some internal info (serial, flags, etc.) that define feature selection?
