• 28.03.2026, 08:55
JoeDorson
Mounting Aquaero XT screen externally.
Saturday, September 14th 2019, 5:22pm
I tried searching the forums and got no hits so I hope I am not repeating something obvious.
My case unfortunately has 0 accessible 5.25 drive bays. I am planning to purchase a Aquaero 6 XT and separate the screen assembly and the actual control board, make a cable to join the lcd/controls and then fabricate some kind of stand alone mount so I can position the display part somewhere else, although I haven't decided exactly where yet.
Is there any technical reason why this wouldn't work?
Thanks for any insight,
Joe
Sunday, September 15th 2019, 3:28am
aquacomputer has a short (≈150mm) extension they use on the airplex GIGANT to mount the display off the aquaero.
Send an email to support at aquacomputer.de for details.
JoeDorson
Sunday, September 15th 2019, 6:23pm
Thanks, I will drop them a line :)
Joe
fragilityV1
Monday, November 4th 2019, 8:00pm
Did you get this resolved? I was thinking of going a similar route.
