• 29.09.2026, 00:53
anoxy
"Connection to Aqua Computer server failed" error during set-up
Samstag, 12. Oktober 2019, 23:46
Hello,
I am trying to install the aquasuite so I can control my new farbwerk nano, however I am getting the following error. I tried disabling my firewall completely, and still it doesn't work.
Any help?
anoxy
Sonntag, 13. Oktober 2019, 01:05
For anyone googling who might be having the same issue as I did, aquasuite does not work on Windows 10. You need to run the set up using Windows 8 compatibility mode.
Please fix this.
gr3if
Sonntag, 13. Oktober 2019, 07:10
No it works normally with Win10...
Looks like your system time is off
Diago
Dienstag, 15. Oktober 2019, 11:36
Please fix this.
Definitely works with Win10.
Is your system an upgraded or a natural win10 install? Maybe it´s a problem if you upgraded to Win10 from Win8
