• 03.01.2026, 12:44
Javik50k
PRO/XT infrared queston
Samstag, 9. November 2019, 19:59
Hello!
I have Aquaero 6 PRO, it is working very well.
But i want to use IR receiver with my Logitech Harmony universal remotes.
What should i do? I don't want to purchase one more IR remote.
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »Javik50k« (12. November 2019, 00:42)
Sonntag, 10. November 2019, 15:06
I believe the aquaero 6 LT does not have IR capability.
The IR sensor is mounted on the left side of the face-plate of the aquaero XTs & PROs
GTXJackBauer
Sonntag, 10. November 2019, 15:32
That's correct. LT's don't have IR.
Javik50k
Dienstag, 12. November 2019, 00:41
I mean, 6 PRO. I have that model, with screen and mechanical buttons. Sorry, was sleepy yesterday.
Donnerstag, 14. November 2019, 04:55
The Logitech Harmony control option availability is probably something to be discussed on their forum.
But to be honest, the only sensible way to manage the aquaero is by using the aquasuite.
Using the IR remote or onscreen buttons is a serious pain-in-the-butt.
