• 31.01.2026, 02:45
andyshinn
Allow disable of system tray icon
Montag, 24. Februar 2020, 08:38
I do not want the aquasuite system tray icon. I would like a feature to disable it. The icon appears when I start the computer or the aquasuite interface.
Montag, 24. Februar 2020, 08:39
You can disable the icon in Playground -> Profiles.
andyshinn
Freitag, 27. März 2020, 23:06
Thank you! I missed that section when I looked around for a setting. Working as intended.
MP7
Dienstag, 28. März 2023, 23:56
How do you disable the profiles tray icon?
