• 31.03.2026, 06:51
cptninc
Aquaero 6 reporting wrong fan speed
Donnerstag, 19. März 2020, 01:01
I have a set of four Corsair ML120 fans connected Ch1 on my Aquaero 6 through a SPLITTY4 RGBpx. When I have this set to be controlled via PWM, the controller reports a varying speed of ~1500rpm regardless of the actual speed of the fans. I have this channel wired and configured identically to how the other three channels are set up, and those seem to work just fine.
Where should I start looking for troubleshooting this?
cptninc
Montag, 23. März 2020, 13:53
Update:
It looks like an accurate fan speed is being reported, but:
  1. Only one of the four fans connected to the SPLITTY4 is spinning that speed
  2. The fan spins that speed regardless of the target RPM.
Might this be a bad fan? I haven't had time to disconnect this fan and see what happens.
Montag, 23. März 2020, 19:05
Have you swaped the fan on the splitty4 from the port that reports RPM with one of the other fans?
