• 10.04.2026, 09:18
UnNameless
Aquasuite Linux support?
Sonntag, 5. April 2020, 22:55
Hi all,
I got a PC (workstation) custom made and I'd like to go with Ubuntu as Windows is just a pain in the ass with Nvidia cards.
The PC has both CPU and GPUz watrercooled and controlled via a hub and Aquasuite software does everything (fan & pump controll, firmware upgrades, flow monitoring etc)
Now the question begs: Is it possible to run aquasuite via Ubuntu, through Wine or similar and have almost all functionality?
If not, would a Windows VM work?
If not, IF i setup the fan & pump speed in Windows and I dual boot in Ubuntu will the settings be kept?
Thanks!
Montag, 6. April 2020, 07:18
The aquasuite work in a VM, you have to disable the hardware monitoring.
UnNameless
Montag, 6. April 2020, 16:44
From Aquasuite?
