• 09.04.2026, 23:50
Hopper64
Aquacomputer G1/4 Flow Indicator | High Flow - USB (53129)
Montag, 11. Mai 2020, 23:55
I will probably add a second high flow sensor (53129) to my system in a different loop independent of the first loop. This is a second loop for the video card. Does the AquaSuite pick up the second sensor in the software? Thanks.
Dienstag, 12. Mai 2020, 01:10
Yes, if you have the USB port on the flow sensor connected to your motherboard, the aquasuite will pick it up.
Hopper64
Dienstag, 12. Mai 2020, 09:49
Thanks!
