• 22.02.2026, 03:56
stingray
farbwerk led
Sonntag, 17. Mai 2020, 06:52
hi guys
im looking to see if anyone knows the wiring of the farbwerk
what id like to do is use one of the farbwerks 4pin channel to run a 2 or 3 pin led light
does anyone know which posts id need to use
thx
Tasky
Sonntag, 17. Mai 2020, 11:11
Pin assignment of farbwerk is
Pin 1: +12 V
Pin 2: GND blue
Pin 3: GND red
Pin 3: GND green
k2viper
Sonntag, 17. Mai 2020, 13:40
3-pin RGB may be 5V D-RGB (or ARGB), a modern rgb standard. 12v farbwerk is not compatible with it. Make sure you're using correct light/strip.
stingray
Sonntag, 17. Mai 2020, 17:37
great,thx guys
