• 10.04.2026, 02:11
stingray
splitty connections
Sonntag, 14. Juni 2020, 15:22
does the splitty 4 connect to the Aquaero via Aquabus connection and show up in aquasuite software as 4 fan channels>?
thx in advance
Sonntag, 14. Juni 2020, 16:07
No, there is not an aquabus port on the splitty4
It is a fan splitter, you run a cable from your fan port (aquaero, quadro, octo) to the 'IN' fan port on the spiltty4.
It works like any other splitter or 'Y' cable.
To control the RGB LEDs on the fans, you connect the RGBpx port on a quadro/octo to the RGBpx 'IN' port on the spilly4
stingray
Sonntag, 14. Juni 2020, 17:34
so only the quatro and octo are,,,which is out of stock everywhere
Sonntag, 14. Juni 2020, 23:28
Not sure where you are located, but, but Highflow.nl in Nederland has some available, as does Aquatuning.us.
stingray
Montag, 15. Juni 2020, 01:59
aquatung price is 49 plus 51 shipping
cant do that,lol
ill do one of these if where i buy from will be very long to stock em
thx alot
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »stingray« (15. Juni 2020, 02:11)
Tasky
Montag, 15. Juni 2020, 03:41
Aqua Computer's own shop has them in stock, no?
https://shop.aquacomputer.de/index.php?cPath=62_3906
stingray
Montag, 15. Juni 2020, 03:50
yes they do
46 for the octo and 59 for shipping
stingray
Montag, 15. Juni 2020, 03:53
i just wish i knew why my A5 isnt working,pulled it out of a working computer but not now weird ?(
