• 29.01.2026, 07:19
jesse.le
Single slot 2080ti I/O backplate
Donnerstag, 30. Juli 2020, 10:39
I converted my 2080ti to a single slot using a aqua computer 2080 nickel waterblock , now I need a single slot I/O bracket. Does anyone know where I can get one or who makes one?
Port are DisplayPort, HDMI, DisplayPort, and the usb-c.
Thanks!
Flop Ysh
Donnerstag, 30. Juli 2020, 22:35
I just googled single slot I/O bracket and found the Bitspower Backplate,I/O bracket for 2080ti : it's a dual one but you can easily cut it
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »Flop Ysh« (30. Juli 2020, 22:39)
