• 22.02.2026, 00:30
ytzelf
QUADRO & LED strip compatibility question
Samstag, 12. September 2020, 20:22
Hi everyone,
I just bought the Quadro and have an old unused LED strip lying around so I was wondering if both things would be compatible (I've seen that aquasuite can easily link LED colors with temps).
The strip is this one : https://www.amazon.com/BitFenix-Magnetic…p/dp/B01K8XF2TC
And I'm also planning on getting the RGBpx cable and female adapter (https://shop.aquacomputer.de/product_inf…roducts_id=3831) as the male one is out of stock; there's a male - male adapter in the strip bundle anyway.
Thanks a lot !
oivind_stenvik
RE: QUADRO & LED strip compatibility question
Samstag, 12. September 2020, 21:06
Hi everyone,
Thanks a lot !
Looks like it's 12V rgb strip and not adressable leds -> not compatible with RGBpx-> https://www.bitfenix.com/products/led/al…d-strips-specs/
Should be 5V
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »oivind_stenvik« (12. September 2020, 21:12)
