• 02.01.2026, 01:43
jaganram
Help regarding farbwerk 360
Dienstag, 22. September 2020, 15:40
I have purchased Ferbwak 360 for my system issue is when i plug in power from PSU and try to turn on PC it wont start, it boots just fine when power is removed
Any idea how can i fix this? I really want install the leds and make it work
Tasky
Donnerstag, 24. September 2020, 02:04
Have you definitely got the Molex and USB cables connected the right way round?
jaganram
Donnerstag, 24. September 2020, 10:39
Yes I tired a different molex too, It wont let me boot PC or I see a power in farbwerk
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »jaganram« (24. September 2020, 11:00)
Tasky
Freitag, 25. September 2020, 03:02
It sounds to me like something is shorting out.
Usually I would expect the USB cable to be upside down on the motherboard header.
Freitag, 25. September 2020, 15:14
I bet that the ESD diode is burned. Please remove the black cover and take a photo of the controller board.
